I have a problem adding a Fixture in ROBOGUIDE.
If I add a fixture from the built-in library, then I have no issues whatsoever. But when I try to add my own model, it's invisible.
I'm following these steps: Click Cell -> Add Fixture -> Single CAD File, then select my .IGS file (see the warnings messages that I get below). I make sure the "Visible" box is checked, and the selector is all the way to Opaque, then click OK. Everything seems to work, I can see the name of the fixture listed in the Cell Browser tree, and I can see the green X-Y-Z marker that was added to the 3D view, but I can't see the actual fixture.
I get these messages, which I assume have something to do with this:
I have the same problem if I Add Machine or Add Obstacle instead of Add Fixture.
Other things I've tried:
-Checked Wire Frame box
-Rotated all around, zoomed in and out as far as possible to make sure I'm not missing it
-Changed Scale to 100x and 1000x
-Tried an .STL file instead of .IGS
-Tried exporting the model to .STEP, then converting it to .IGS
-Tried exporting to .STL, then converting it to .IGS
I don't know what else to try. If anyone has suggestions I would appreciate it!
